VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 03-15-2004, 09:39 AM
danalihd danalihd is offline
Junior Member
Send a message via AIM to danalihd Send a message via Yahoo to danalihd
On the way to work this morning my truck was running kinda weak. I floored it from a dead stop and got it up to about 100 before letting off. It seemed to be holding back on me and I got the 2 above mentioned coded on the Predator. Any ideas? Incase I haven't mentioned it, I have a 6.0L with a whipple with stock pulley and a Nelson tune.
  #2 (permalink)
Old 03-15-2004, 02:02 PM
farmtruc's Avatar
farmtruc farmtruc is offline
Senior Member
Send a message via AIM to farmtruc
Did anything change, how about that smaller pulley.
The 131 is a oxygen sensor code. Low circuit on bank 1, sensor 1. How does the voltage look with the predator? During normal driving, the 02 voltage should go way up and then down, all over the place, if it is stable or lazy, you have a dying 02 sensor. At wot, it should be 900+mv.
the 151 is circuit low, bank 2 sensor 1. Same thing on this one. Looks like both front 02's didn't like something.
Let me know how those 02's look at wot.
allen
__________________
Performance Programming and Installation
Nelson Performance
  #3 (permalink)
Old 03-15-2004, 04:03 PM
Bandit Bandit is offline
Member
Since both banks show a code, first thing is to verify them like Allen said by monitoring the O2's. If they are biased lean (stay under 450mv mor than going over) then look at fuel trims. If STFT or LTFT is adding tons of fuel, then check fuel delivery like a filter or pump.
Bandit!
__________________
Jason B. Armstrong, L1, AAM
http://www.danasoft.com/vipersig.jpg
  #4 (permalink)
Old 03-16-2004, 12:14 PM
Junior Member
I had my wife watch the O2 sensors while i drove. The 2 in question never hit 900. I think the max was around 800. They were all over the place while driving. Also, the Ltrims did seem to lock at 0 at WOT, but, I also am gettin KR up to 4 at WOT. Nothing has changed, I don't understand it. It was running great. It's almost like the tune got lost somehow. This is all happening with the stock, 6lb pulley. I ditched the 8lb pulley for the time being. It has only been around 4000 miles since I changed the fuel filter and I'm getting great fuel pressure. at idle it is 52psi and at WOT it goes up to around 70. I did notice the other night that the spark dropped way down to 3 for a second at WOT.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
