VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 03-02-2004, 11:51 AM
Trucked-up Trucked-up is offline
Junior Member
I have a 99 GMC ECSB w/ a 99 TA LS1. Only mods are polished throttle body, UPD lid, 373 gears w/eaton locker. I used the truck intake.
I am getting 8 degrees of knock retard, beginning at about 70% throttle. Other than that the truck runs great. 250 rwhp & 296 lb/ft of torque.
I have run 100 octane and the knock is still there.
If I purchase a new PCM and program it will this get rid of the knock?
If I replace the knock sensors? The sensors for the LS1 and the 5.3 are the same.
Thanks,
Tony
__________________
99 GMC, ECSB w/ LS1 from 99 TA
E-fans, 3:73, Eaton posi
  #2 (permalink)
Old 03-02-2004, 02:03 PM
L82gofast L82gofast is offline
Senior Member
Sure sounds like false knock if its still there with 100octane gas. Not sure if a PCM will help you out. Try putting a 10k resistor in line with each knock sensor to desensitise them and if it helps, I would go after replacing them.
Mike
__________________
'02 1500HD, 6.0L, magnacharger, 2000stall, custom magnaflow with electric cutout, E-fans, Nelson custom tune, Auburn LSD.
'79 L82 vette, Summit 355, Dart Pro1 heads, Comp 274 cam, Holley TBI, Built TH350 with 2500stall
'93 Blazer, full size 2dr 4x4, new project.....
  #3 (permalink)
Old 03-02-2004, 04:08 PM
farmtruc's Avatar
farmtruc farmtruc is offline
Senior Member
Send a message via AIM to farmtruc
If that doesn't work, try getting your PCM reflashed with a newer calibration. GM comes out with many updates to the PCM and sometimes it's for knock.
go to http://calid.gm.com:8082/VINEntryPre.do and see if there's any updates.
if so, I can flash your pcm for you.
later,
allen
__________________
Performance Programming and Installation
Nelson Performance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
