VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 02-17-2004, 12:01 PM
Trucked-up Trucked-up is offline
Junior Member
I have a 99 GMC Sierra ECSB with a LS1 from a 99 TA. I have been logging my knock retard with EASE diagnostics and am getting a consistant 8* of knock. I have read that 99 trucks are notorious for this problem.
I put 5 gallons of 100 octane gas in and logged again, still 8* of knock. Based on this I believe I am getting "false" knock. I would like to de-sensitize my knock sensors. I have read on other forums about putting a 10K ohm resistor in line with each sensor. The knock sensor harness that goes from the back of the intake to the pcm is where I would like to install the resistors. I would like to make a short section to install these resistors in line so that I can un-plug them when I want to.
Does anyone know the GM part number for the 2 connectors I will need.
Has anyone on this site performed this mod and if so what resistor values did you use?
Thanks for the help.
Tony
__________________
99 GMC, ECSB w/ LS1 from 99 TA
E-fans, 3:73, Eaton posi
  #2 (permalink)
Old 02-17-2004, 12:47 PM
Bandit Bandit is offline
Member
Not exactly what you described but see if this helps:
Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace
Rear Bank Knock Sensor and RTV Area Around Sensor) #02-06-04-023A -
(06/14/2002)
Rear Bank Knock Sensor and RTV Area Around Sensor)1998-2002 Chevrolet Camaro,
Corvette
1998-2002 Pontiac Firebird
with 5.7L Engine (VIN G -- RPO LS1)
1999-2002 Chevrolet Silverado, Suburban, Tahoe
2002 Chevrolet Avalance
1999-2002 GMC Sierra, Yukon, Yukon XL
2002 Cadillac Escalade, Escalade EXT
with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59,
LQ9, LQ4)
This bulletin is being revised to add Cadillac Escalade and Cadillac Escalade
EXT to the Models. Please discard Corporate Bulletin Number 02-06-04-023
(Section 6 -- Engine/Propulsion System).
ConditionSome customers may comment on a mild to severe engine ping (commonly
referred to as spark knock), usually worse during acceleration and/or an
illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
CauseThis condition may be the result of corrosion of the rear bank knock
sensor due to water intrusion into the sensor cavity. This condition is more
apparent on vehicles in which customers frequently wash the engine
compartment.
CorrectionReplace the rear bank knock sensor and build a dam (wall) around
the sensor using RTV to divert water away from the sensor. Use the procedure
and part number listed below.
Remove the intake manifold. Refer to the Intake Manifold Replacement
procedure in the Engine Controls sub-section of the appropriate Service
Manual.
Remove the wiring harness assembly from the knock sensor.
Remove the rear bank knock sensor.
Install the new rear bank knock sensor. TightenTighten the knock sensor to
20 N·m(15 lb ft).
Install the wiring harness assembly to the knock sensor.
Apply a bead of RTV silicone sealant approximately 9 mm (3/8 in) wide and
6 mm (1/4 in) high along the outside edge of the ridge on the engine block
valley cover around the rear bank knock sensor. DO NOT form a complete
circle. Leave the rear section open as shown.
From the underside of the intake manifold, completely remove the rear intake
manifold seal (foam material).
Install the intake manifold. Refer to the Intake Manifold Replacement
Manual. Parts InformationPart Number
Description
Qty
10456603
Sensor, Knock
1
Parts are currently available from GMSPO.
I have seen and repaired a few of these. Another thing to do is get on http://calid.gm.com and see if there is a flash update available to rectify the problem.
Bandit!
__________________
Jason B. Armstrong, L1, AAM
http://www.danasoft.com/vipersig.jpg
  #3 (permalink)
Old 02-17-2004, 02:43 PM
BigKID's Avatar
BigKID BigKID is offline
Senior Member
Send a message via ICQ to BigKID Send a message via AIM to BigKID
I have done exactly what you described and it works great. I dont know the pn for the connectors. I just went to the salvage yard and yanked some off a wrecked truck. The same connectors are all over the engine bay. Just make sure you solder the resistors on rather than using but connectors and use some heat shrink to cover them.
__________________
2000 Silverado, RCSB, 2wd w/ a few mods.
Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
2001 Tahoe LT 4wd
Stock, daily driver and tow vehicle.
  #4 (permalink)
Old 02-19-2004, 11:42 AM
Flyer Flyer is offline
Senior Member
I remember reading somewhere that the knock sensros are engine specific. You may try getting new sensors for that size engine, not necesarilly your truck, but what ever the engine came out of.
The reading said something about the knock sensors are calibrated to pick up knock on a given displacement engine since different displacement will have different 'sounds' and will have a different 'tone' of knock.
__________________
Arrival Blue 2003 Chevy Silverado RCSB (stepside) w/ 5.3 and an exhaust leak.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
