VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 02-14-2004, 06:57 AM
97 SS 383 97 SS 383 is offline
Junior Member
I read a post somewhere about Nelson tuning programming electric fans to work using the truck computer, I was wondering if that programming also makes them come on when the A/C is switched on, or if it is only by temperature.
  #2 (permalink)
Old 02-15-2004, 11:25 AM
02P3wZ71 02P3wZ71 is offline
Member
Mine is set to turn on by temperature. I don't think that it can be tuned to turn on with the A/C as well. It just isn't possible to wire it up to do all of that. That is what was explained to me, maybe Allen can work magic!
__________________
AKA 02PewZ71
Can't call myself 02PewZ71 anymore, my new name is Haulinbass02 (dieselplace.com)
My new baby: '02 CC/SB 4x4 2500HD
DURAMAX (LB7)/ALLISON
Got an intake and Magnaflow exhaust for it now
  #3 (permalink)
Old 02-15-2004, 06:36 PM
Junior Member
If he can, I may have plenty of work for him.
  #4 (permalink)
Old 02-23-2004, 09:50 PM
badseed91 badseed91 is offline
Senior Member
Send a message via AIM to badseed91
How does the computer on the camaros know the ac is turned on? Im sure that it cant be that hard to find a way to hook the a/c into the cycle to get the fans to come on once the a/c is turned on.
__________________
http://i82.photobucket.com/albums/j2...CSigCamaro.jpg
EATIN' FORDS AND $HITIN' TUNDRAS
2005 VHO ecsb 6.0HO, Comp Cam, CAI, Thermostat, 2800 stall, G80 3.73's.
  #5 (permalink)
Old 02-24-2004, 12:58 PM
farmtruc's Avatar
farmtruc farmtruc is offline
Senior Member
Send a message via AIM to farmtruc
The truck pcms are setup to turn the fans on, but only one output is available, I just got the latest version 1.4 edit and there is an update on the second output temp control, I'll have to play with this.
Most ppl complain the fans come on at the same time and drain the truck for a sec, having that second output would be nice. One fan at at time.
As far as the ac. Check the pinouts, the trucks also have an output or sense line for the ac. It's not necessarily meant to turn on the fan when the ac comes on, but any wire/pcm pin, that changes from 0 to 5, or 5 to 0volts when the ac comes on will work. You're just looking for a signal change
I'll keep you guys updated on the second pin output.
later,
allen
btw, you do need edit to change the fan temp settings in order to activate the fan output/control line.
__________________
Performance Programming and Installation
Nelson Performance
  #6 (permalink)
Old 02-24-2004, 03:16 PM
GMCwantsLS1's Avatar
GMCwantsLS1 GMCwantsLS1 is offline
Turbo Moderator
Send a message via AIM to GMCwantsLS1 Send a message via Yahoo to GMCwantsLS1
Quote:
Originally posted by badseed91@Feb 23 2004, 08:50 PM
How does the computer on the camaros know the ac is turned on?* Im sure that it cant be that hard to find a way to hook the a/c into the cycle to get the fans to come on once the a/c is turned on.
On the Camaros the switch on the dash sends a positive 12V to the PCM then the PCM tunrs on the compressor. The PCM then senses the high side pressure and when it gets high enough it turns on the fans. I think all you need to do is turn on the fans when the compressor is on. Just tap into the compressor 12V+ wire and use that to trigger your fan relay.
__________________
2002 GMC Sportside Denali front end with a 2002 LS1, FLT level 5, Yank 2600, Trick Turbo, T76, Nelson intercooler, 60LB injectors, Warbro fuel pump, Eaton locker, Magnaflow, 3.42, Nelson Performance Tuning (speed density).
1981 GMC LB RC 1500 2002 4.8L 4L60E 12 bolt 3.73 Richmond Lock Right AC PS Nelson Performance tuning
  #7 (permalink)
Old 02-29-2004, 09:25 AM
Junior Member
Quote:
Originally posted by GMCwantsLS1+Feb 24 2004, 02:16 PM--><div class='quotetop'>QUOTE(GMCwantsLS1 @ Feb 24 2004, 02:16 PM)</div>
Quote:
<!--QuoteBegin-badseed91
On the Camaros the switch on the dash sends a positive 12V to the PCM then the PCM tunrs on the compressor. The PCM then senses the high side pressure and when it gets high enough it turns on the fans. I think all you need to do is turn on the fans when the compressor is on. Just tap into the compressor 12V+ wire and use that to trigger your fan relay. [/b]
The problem is not making the fans come on when the A/C comes on using extra wirin and relays, I have done that for years. What I would like is to not have to do that anymore. If someone can actually have the computer do it, that would be cool.
I didn't realize you were using LS1 edit for all of this, I thought you actually had the GM computers and programming skills. I have had great luck thus far with Fastchip/Ed Wright, I thought maybe you were doing something like him.
  #8 (permalink)
Old 02-29-2004, 11:15 AM
Turbo Moderator
On mine I have the PCM "AC Request" on my truck hooked to the wire that goes from the controler on the dash that turned on the old compressor. I had to add the high side pressure switch so the PCM can sense the AC pressure and turn on the cooling fans. Works just like the camaros do, in other words the PCM controls all fan functions for temperature and AC! Most don't do it like this and say it is too much trouble, but I like it working like the factory intended it to.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
