VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 01-30-2004, 08:29 PM
GREGGO GREGGO is offline
Member
Finally got edit and took it to MTI to get Jayson to get me started on t. Long stry short, it won't read my PCM. It stops and says to connect the USB adapter and/or OBDII cable. I have both on my laptop and am using the OBDII cable. FWIW, the same cable will read fine with AutoTap. So is my box bad?
  #2 (permalink)
Old 01-30-2004, 09:56 PM
honkydaddy honkydaddy is offline
Senior Member
Hey Greg,
Cable come with the box,or the Auto Tap Sounds like the cable has the wrong configuration on one side,or both of the box.
Willie
  #3 (permalink)
Old 01-30-2004, 10:43 PM
farmtruc's Avatar
farmtruc farmtruc is offline
Senior Member
Send a message via AIM to farmtruc
Quote:
What kind of port are you using on the laptop, the usb or com port?
What com port are you using?
Can you read another truck/pcm with you cable?
not sure if it takes a vin if you do that?
allen
__________________
Performance Programming and Installation
Nelson Performance
  #4 (permalink)
Old 01-31-2004, 11:58 AM
BigKID's Avatar
BigKID BigKID is offline
Senior Member
Send a message via ICQ to BigKID Send a message via AIM to BigKID
You should be able to read anyting. The VINs only set permissions on uploading files to the pcm. The interconnect cables from Autotap and Edit have the same pinout configuration and are interchangable so that shouldnt be the problem. Do the the leds light up when ever you plug it into the diagnostic port. I think the one on the far left stays lit all the time when connected. Then the others flash on transfer.
__________________
2000 Silverado, RCSB, 2wd w/ a few mods.
Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
2001 Tahoe LT 4wd
Stock, daily driver and tow vehicle.
  #5 (permalink)
Old 01-31-2004, 02:34 PM
Senior Member
Hey bigKid,
Is the program setting the permissions or the box.
Willie
  #6 (permalink)
Old 01-31-2004, 05:48 PM
BigKID's Avatar
Senior Member
The vins are stored on the box. When you first get it has however many free vins slots you paid for and marries itself to the first vin(s) you try to upload to. It will come up with a confirmation message asking if you want to marry the cable to this vin number.
Greg.. also check when you open the program while connected to the truck to see if you vin pops up in the 'licensed to:' box at the top of the screen.
__________________
2001 Tahoe LT 4wd
  #7 (permalink)
Old 01-31-2004, 10:16 PM
Bad03Chevy Bad03Chevy is offline
Junior Member
The High-Performance PCM Programming souunds like a good dea. I like the tought of being able to hook up my laptop and tuning it myself. Where can I go to get one of these?
__________________
2003 LT, 5.3L Silverado Z71 Dark Grey Metalic
AEM Brute Force intake
Cat back Flowmaster 40 serries 3" duals
Bosch Platinum +4 plugs
  #8 (permalink)
Old 01-31-2004, 11:09 PM
Senior Member
Hey Bad03Chevy,
Type LS1Edit into your search box on internet explorer.Should bring up their website.I think it's kind of exspensive.Think I saw it was $2400,may be wrong there.I'm looking for something like that also.Think I saw the price and gave that up.I've got an LT1 and don't know if it will work anyway.One nice program though.I need something I can change while I'm driving.Want to get rid of my speed limiter too.I'm going to drive mine everyday and will make trips to Texas in it too,so I'd like to be able to change my settings anytime I need too.Thought about a Hypertech,but it doesn't look like it will do everything I want.Got a list of about 15 different programs to check on.Come up with a reasonable one I'll let you know.
Willie
  #9 (permalink)
Old 02-01-2004, 11:57 AM
BigKID's Avatar
Senior Member
http://www.carputing.com
btw... Honky.. the make LT1 Edit too and that $2400 you saw must have been an unlimited tunner version. Normally runs $550 for a single vin and 150 for each additional vin up to four.
Greg... any new news?
__________________
2001 Tahoe LT 4wd
  #10 (permalink)
Old 02-01-2004, 01:49 PM
Senior Member
Yeah BigKID,
That sounds a lot better.Appreciate the link.Thought $2400 was a little high.
Willie
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
