Normal O2 switching occurs between 200 and 800 millivolts, with 450mv being the switch point. During normal running conditions, is is not unusual to see voltage as low as 100 mv and as high as 900mv. During WOT, voltage should immediately go to AT LEAST 900mv, and may reach 1 volt or a little higher. Going over about 1.2v can sometimes cause problems, as there might not be a strategy for voltage that high, so the computer reasons that since voltage is not between 450 and 1.2 millivolts, the system must not be rich, so it has to be lean. That can cause all sorts of problems!
Bandit!
