VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 01-13-2004, 12:30 AM
farmtruc's Avatar
farmtruc farmtruc is online now
Senior Member
Send a message via AIM to farmtruc
Ok, I've been researching this topic and I hope someone chimes in to add to it or debate it.
Some ppl seem to think that zeroing the shift time values within ls1edit will cause problems in the transmission. The theory is, if there is no shift time delay, then both soleniods will be "turned on" at the same time, causing two different gears to be engaged at the same time. This sounds bad, but wait.
I was just tuning some 03 and a 04 SS truck pcms and I was looking at how GM is setting that table up. They actually ZEROED out the 3-4 shift delay and they decrease the time as torque/power/tps go up. I don't always agree with GM and their tuning practices , but I will stick with one thing they do, they detuned the **** out of these trucks. And, if GM thought it would cause problems or make for a harsh ride , I know they wouldn't of zeroed that row out. Hell they would make it shift as slow and soft as possible, lol.
So has anybody else heard or think different, if so post it, yo, i'd like some input,
thanks,
allen
__________________
Performance Programming and Installation
Nelson Performance
  #2 (permalink)
Old 01-13-2004, 12:37 AM
GMCwantsLS1's Avatar
GMCwantsLS1 GMCwantsLS1 is offline
Turbo Moderator
Send a message via AIM to GMCwantsLS1 Send a message via Yahoo to GMCwantsLS1
JMO but I don't think the tranny can react as fast as the electronics, so even if both soleniods were on at the same time for a fraction of a second it should cause no harm. I'm sure GM is trying to extend the life of their trannies and I would think shortening shift times would help, then add in a bit of TM and you will soften the shifts back up.
__________________
2002 GMC Sportside Denali front end with a 2002 LS1, FLT level 5, Yank 2600, Trick Turbo, T76, Nelson intercooler, 60LB injectors, Warbro fuel pump, Eaton locker, Magnaflow, 3.42, Nelson Performance Tuning (speed density).
1981 GMC LB RC 1500 2002 4.8L 4L60E 12 bolt 3.73 Richmond Lock Right AC PS Nelson Performance tuning
  #3 (permalink)
Old 01-13-2004, 10:46 AM
farmtruc's Avatar
Senior Member
I agree, mechanicals are always slower than electronics.
So, if one soleniod turned off and the othe turned on, the mechanicals would still have a delay.
thanks for the input,
allen
__________________
Nelson Performance
  #4 (permalink)
Old 01-13-2004, 12:57 PM
BigKID's Avatar
BigKID BigKID is offline
Senior Member
Send a message via ICQ to BigKID Send a message via AIM to BigKID
I have had mine zeroed out for some time now and it dosnt seem to be having any adverse effects. Also, every fbod file I have looked at has been zeroed out in stock form.
__________________
2000 Silverado, RCSB, 2wd w/ a few mods.
Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
2001 Tahoe LT 4wd
Stock, daily driver and tow vehicle.
  #5 (permalink)
Old 01-13-2004, 12:59 PM
Hit Man X Hit Man X is offline
Senior Member
Send a message via ICQ to Hit Man X Send a message via AIM to Hit Man X Send a message via MSN to Hit Man X Send a message via Yahoo to Hit Man X
Slow shifts cause heat buildup and heat = bad for the trans...so I'd think you'd want it to shift as quick as possible.
Have you tried playing with the shift times to see if it adds to harshness of them?
Wouldn't shift delay be having each gear on at once? Thus no shift delay meaning faster shifts? Thats how you get soft shifts as they overlap.
__________________
  #6 (permalink)
Old 01-30-2004, 12:55 AM
deezel deezel is offline
Junior Member
I've played with shift times a bit. Haven't been able to make it shift faster, but tranny is still stock. Likely lowering the shift times has more effect with a shift kit... Same argument made above - the hydraulic circuits and mechanical parts can only move so fast.
__________________
2003 Silverado SS, Black
e-fans, custom ram air, LS1Edit tuning
  #7 (permalink)
Old 02-05-2004, 10:31 PM
Flyer Flyer is offline
Senior Member
I was doing some reading on the abuse mod over on ls1tech. I came across a thread about this table. Someone in there suggested that the shift time table may be connected with the spark retard limit on the Ignition tab. They mentioned something like the values in there are what tell the PCM to use for timing during the shift and the shift time tables tell the PCM how long to use the timing in this table.
I 0'ed out the retard limit table and am not seeing any drop in timing when the truck shifts (slipping band goes from it's slipping to oh **** when this happened). I also removed all of torque management at the same time too.
__________________
Arrival Blue 2003 Chevy Silverado RCSB (stepside) w/ 5.3 and an exhaust leak.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
