VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 01-02-2004, 05:25 PM
yeary03SS yeary03SS is offline
Senior Member
Send a message via MSN to yeary03SS
Right now my computer is programmed for 44 lb/hr injectors. If I put the stock ones back in, will it run fine at least to make it to the dealership about 15 miles away for a reburn or will it probably spit and sputter and throw a few codes? I know putting the bigger ones in with a stock tune won't run very well, but i'm not sure about the other way around. Any help would be appreciated.
Kyle
__________________
2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
  #2 (permalink)
Old 01-02-2004, 05:44 PM
Bandit Bandit is offline
Member
It should be okay, but if you are that worried about it, why don't you pull the pcm and take it to the dealer to be flashed? Most dealers have bench flash capabilities. Call them and ask. You should only need the PCM and the VIN.
Bandit!
__________________
Jason B. Armstrong, L1, AAM
http://www.danasoft.com/vipersig.jpg
  #3 (permalink)
Old 01-02-2004, 05:49 PM
Senior Member
The closest dealership to me said i'd have to take the truck in. I'll call again tomorrow and talk to someone different. Thanks for the help.
__________________
  #4 (permalink)
Old 01-03-2004, 03:56 AM
farmtruc's Avatar
farmtruc farmtruc is online now
Senior Member
Send a message via AIM to farmtruc
man, going from 44's to 24lb's a big difference, your injector flow rate is probably about 5 or so, 24's are about 3.18, it may run, but DON'T GET ON IT!!.
You'll be running lean like a mofo.
Going from small to big is fine, it'll just run rich which is ok for a while, but the other way around...
Let me know what happens, I bet it spits and sputters and has a bad hesitation, hope if goes well,
allen
__________________
Performance Programming and Installation
Nelson Performance
  #5 (permalink)
Old 01-03-2004, 10:17 AM
Member
Some parts suppliers offer bench flashing, too. Or you could just box it up and send to Allen....
Bandit!
__________________
  #6 (permalink)
Old 01-03-2004, 01:20 PM
Senior Member
Allen,
So I should be ok if I go to the dealership and have them reflash it with the bigger injectors in? I can then drive home running rich and put the 24 pounders back in? Will it idle with it running that rich? I can just see the dealership now flashing it back and it not running fine and have them try to diagnose everything and tell me a bunch of crap is messing up. I'm definately going to you next time for tuning.
Kyle
__________________
  #7 (permalink)
Old 01-03-2004, 02:14 PM
farmtruc's Avatar
Senior Member
If you have the 44's in now, and want to put 24's in, I'd rather run rich on the way home instead of lean on the way up there, just my opinion, but it's much safer to run pig rich instead of real lean. You may foul a plug or two, but at least your won't stumble, hesitate and possibly detonate.
You may even have to keep the truck running by using the gas and brake at lights, but once you're going it should run, but rich.
good luck,
allen
__________________
Nelson Performance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
