Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 248
Thread: my 2002 silverado build [2014] revision
    Pittsburgh, PA
    Some of you have followed my truck over the yrs. From its first turbo setup in 08 to its twins in 2010 and now for 2014 the truck is going back to an auto. I had enough of the issues that are related to the manual and power setup for me the change and go back to an auto. The last issue was my firewall split from the clutch master, with all the pressure always applied from the pedal.
    so for this revision of the truck i got rid of alot of un needed weight. Weight form the skirts, weight from the front bumper, system and etc
    for this go around i decided to go back to my LS2 and topped it off with a set of trick flow 220s, Isky 218/218/112. the rings were opened up to .028 so it should be little more boost friendly. Tossed in a set of LS9 gaskets
    decided to go with N.O. coolant crossover
    decided to make a T5 log for my Pt91.5 and decided use a precision 66mm gate
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Pittsburgh, PA
    heres a few pics of the holley hi ram that i shaved off teh TB bracket and made my own. Gotten the idea from a friend
    motor was basecoat/clearcoat PPG arrival blue with PPG clear
    412 Motorsports
    Looks great as always
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Pittsburgh, PA
    i then wanted a change in interior, so went with SEM landau black interior dye and had my panels dyed black. Also went ahead and had my headliner redone in black suede
    at this point i felt it was time to stiffen up the chassis some by doing a roll bar. I went ahead and did a 8 point chromo
    with with 3/16 polycarbonate for the rear glass
    wanted removable door bars as this is a street truck and not a full race truck. the wife wanted the door bars to be removable for when she drives the truck
    412 Motorsports
    Pittsburgh, PA
    with it being time to go auto, i contacted DTR fab and got on of their 80e tubular crossmembers
    picked up a 3600 multidisk Circle D converter
    went with a TCI SFI flexplate for the auto swap
    412 Motorsports
    Pittsburgh, PA
    since im switching up the appearance some i went with a SS bumper cover and had it modded to work with the HD grill. the bumper is currently in the rough stage and will be smoothed out once it goes to the painter.
    i went ahead and removed the factory style bumper and its frame horns. I took a page from the Lightning crowd book and bolted my grill and bumper cover together
    bumper is pretty sturdy with it being bolted to the fenders on the sides, i also used the stock side brace arms and make a strap to tie in the bumper cover behind the brake ducts
    doing this mod i lost 65lbs off the nose of the truck
    412 Motorsports
    Pittsburgh, PA
    went ahead and welded a 4" vband to the compressor housing
    then proceeded to weld a 2.5" vband to my driverside manifold
    picked up a 28x13x5 garrett core to build my intercooler from
    412 Motorsports
    Pittsburgh, PA
    picked these up to replace my heavy leather stockers, these are two tone suede these allowed me to drop 70lbs from the truck
    412 Motorsports
    Pittsburgh, PA
    to help control boost i went with AMS500 and c02 kit
    412 Motorsports
    Pittsburgh, PA
    Street truck...that is more focused on working for me not against me...won't be any kind of killer till I can build a motor to handle the turbo.
    With building a ford motor for lightning my motor money is tied up for now
