View Poll Results: which gears
Voters
39. You may not vote on this poll
  • 4.10
    31 79.49%
  • 4.56
    6 15.38%
  • 4.88
    2 5.13%
Results 1 to 10 of 11
Thread: Gear question
    newburgh, NY
    Gear question
    Well I have been having problems with the mighty 4L60E and I am looking for a 4L80e. I am going to change gears also currently it is a 4.8 with 3.73. mods are tune, headers, pulleys, CAI, and fans. I haven't really decided where I am going with the engine but I am starting with a trans. I am undecided on what gears 4.10, 4.56, or 4.88. On a 4l80e how are the cooler lines attached to the trans?
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Nov 2009
    chicago, il
    I would do 4.10, but that's just because I still drive on the e-way alot and my tires are only 33". A 4.10 may also be about the same in a 4l80e and your 3.73 is in a 4l60e.
    Don't bother changing gears, just a put in a 10" 3000rpm stall converter. It will allow the engine to come up on the power curve quicker as you accelerate.
    Pittsburgh, PA
    4k stall 456 gears and that 4.8 will come alive
    What do u have planned for the truck street or strip or both?
    Quote Originally Posted by trx2stroke4life39 View Post
    80e behind a 4.8L???
    As for the cooler lines, it all depends on what year 80e you have. Some have the coolant lines stacked on top of each other (like the 60e) and some have one in front and one in back.
    2000 ECSB 5.3L
    228R CAM ● COMP 918's ● 7.4 HARDENED PUSHRODS ● K&N SERIES 77 CAI ● 80mm BBK ●PACESETTER LT HEADERS AND 3'' ORY ● SUPER 40 FLOW ● 3000 STALL ● 4.10s ● BUILT 60e ● VORTEC PERFORMANCE TUNE ● MSD 8.5mm PLUG WIRES● ELEC. CUTOUT ● UD & ALT PULLEYS ● FLEX-A-LITE E-FANS ● CENTERLINE STINGRAY III's ● LUND FIBERGLASS TONNEAU ● 2" LEVELING SHACKLES ● 12K HID LOWS & FOGS ● LEDs ● DEBADGED ● WHITE-FACED ESCALADE GAUGES ● KICKER 450.1 ● 2-CVR 10's ● DS60's ● K693's
    4.8L + 80e is a common setup for GM utility vans.
    newburgh, NY
    I am starting with the weak link first.
    It will driven daily I was only planning on a 3000 stall converter.
    Step 1. crus at it.
    Step 3. torch it.
    Pittsburgh, PA
    stock 80 converter i think is 2600
    newburgh, NY
    Aren't the factory really heavy?
    Step 1. crus at it.
    Step 3. torch it.
