what heads are best for n/a lq4 6.0 ? I have the 317's casts. would ls1 or ls6 heads work better for n/a ? or should i use the 317's have them gasket matched ported? And i will be putting a ls1 intake on it.
if you milled the 317's couldnt you get the same results? plus saves buying another set of heads. just a thought
2005 SS AWD, 22" REPLICAS, VOLANT CAI, MAGNAFLOW EXH, 1/2 DROP- NEXT: TUNE, SHIFT KIT, SERVOS, TRU-COOL
(SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" C6 Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS: NEXT-LSX 370/PT88/TH350
He can mill the the 317's but in order to get the same result as stock 243's, they would have to be milled .050. That would be too much to mill off on a 317 since you could start running into piston to valve clearance issues with larger cams. It would put CR around 10:1. The most you should mill them would be .030 which would put your CR in the 9.75:1 range. If he got 243's milled .021 (61cc combustion chambers), then the CR would be close to 10.5:1 with the same flow.
The dished pistons make a big difference when trying to stay N/A.
LS2 heads are 320 a piece brand new fully asembled from SDPC. 66cc chambers, 2.00/Intake 1.55/Exhaust valves and they flow the ame as 243's
www.tjc.edu
from what ive read they LS2 is the same just without the sodium filled vavles. but i could be wrong. like molitor said same flow numbers
Wow, look at Jay trying to make fun of me because he is pissed cause his wife has his cajones in her purse--right next to his Man Card which was taken YEARS ago, won't let him even go to the bathroom without telling her first, and does not have the huevos to wrench on his own truck. Justify it however you want--Jay is still Captain of the Gay Train.
Yes, I AGREE with the Captain.
+1
Yes, the 243s assembled from the factory on Z06 cars come with those valves and higher rate springs.
