Thread: 95 silverado swap to 04 5.3
    Aug 2006
    my brother is thinking of swapping his 350 in his 1995 silverado with an 04 5.3
    How easy would this swap be? I'm assuming he will need to swap w/ the new computer also.
    Should it be that simple?
    Swap out motor/tranny and computer, and crank it up? Theoretically....
    Or is there some fab that needs to be done?
    thx for any info, found a great deal on a 5.3/4l60, and he wants to breaathe new life into the 95, too many miles
    86 C10 6.0/4l80e
    Dec 2005
    Do a search and you will get a plethra of info, I believe on a 95 350 it already has the high pressure fuel pump so all you need is to modify the fuel line with a corvette fuel filter that has the regulator. Look up past replies from Redheartbeat he pretty much explains it all.
    91 Silverado 2005 5.3 ,transgo hd2, Yank2600, Nelson Tune, 3" exhaust, 4-6 drop
    2004 Silverado crewcab 5.3 3'' Magnaflow exhaust
    mob-town
    check out the sticky on the top of this section.. I am in the process of doing the same thing except with a 94 and all the info is there..
    Looking for a 05-07 Ext Cab or Crew Cab Chevy or GMC with some mods.. PM if you have anything
