Since you're not going to be using any of your fuel injectors, every pink wire in the injector plug is ignition fused feed. What plug is the white wire in the PCM ? The only large white wire I remember is the IC ontrol in the C3 clear plug on the PCM. You should have plenty of pink wires left over in the old harness that go back to the fuse box under the hood. I think I remember at least 6 that I pulled out or capped for future use. I started by pulling the old harness off and cutting off the plug from every thing I knew I wasn't going to use anymore. Fuel injectors, 02 sensors, crank position sensor, Inlet air, EGR, MAP, IAT, MAF, TP, Purge canister EVO solenoid on the power steering, etc....Then I pulled all of those wires and removed them from the 97 harness. You'll be suprised on how little bit of factory wiring you'll have left. A friend and I made a stand alone plug and play harness for the starter, fans, a/c and pcm with factory weather pack connectors. Then I just had to splice something like 6 wires and a ground. Hope this info helps.
