Thread: 2000 6.0l swap into 97 5.7l Chevy silverado
    Nov 2017
    Ok so I just picked up a 97 Chevy Silverado that had a 5.7 in it still has the 4l60e and I have a 2000 gmc Sierra with 6.0 the body on the 2000 is rusty so I want to put that engine into the 97
    From what I read I need some kind of spacer on the flywheel and to modify the original motor mounts for the 97 then address the wiring is there a company that makes a plug n play harness and where can I find the flywheel adaptor
    Apr 2017
    Northeast Ohio
    Try summit for the flywheel adapter. Here is the Summit part number SUM-704000. I havent put my on yet but there are a few different threads on here where you can find installing information. Best of Luck!
    Sep 2011
    that spacer goes in between your crank and flexplate,
    as for the wiring end of it I sent you a PM
