Thread: 91 chevy 1500 ls or lq9 swap help!!!!
    Jan 2017
    ok so to start off I have a 91 chevy stepside its lowered and its a lil rough tho I just bought it and I have around 4 thousand bucks to spend maybe 5 on a swap I cant decide whats a better swap a ls1 or ls2 or even lq4/lq9 its going to be a street truck not a drag truck but I want reliable im sure this has ben covered in another thread but im just asking for help for someone who has done the swap wat all do I need like motor mount wise and im not sure what trans ill do yet my truck is a automatic I don't know if I want to stay auto or do a t56 but if I do go t56 what kits are out there to make this as easy as possibl thanks!
    Sep 2011
    Your easiest swap will be a truck engine, if lowered you'll need to get the GM muscle car oil pan, dirty dingo motor mounts, stand alone harness and a later model 4l60E transmission.. that will be a reliable combination for a street driver
    Mar 2016
    BC Canada
    The truck pan will still work but does hang about 2" below the cross member. I haven't smoked mine yet and I'm lowered 4/6 with small tires
    1995 rcsb c1500, 4/6 drop, 5.3 L33, 5spd, 219/228 112LSA cam, LS6 springs, 799 heads, long tubes, magnaflow mufflers
    San Marcos Texas
    The fbody or the corvette pan will work fine.
    Jan 2017
    so I ended up getting a 2005 lq9 ayone know about what headers you have to use? can you use stock manifolds?
    Mar 2016
    BC Canada
    Stock manifolds will fit. Or you could use schoenfeld ls swap headers.
