I haven't been on this site since last time I did a Dodge to LS swap. The 1999 Dakota R/T I built runs fantastic. Using a 6.0 with 6L80, I added an LS9 cam with car intake, and run about 12.5 at 107 all day long.
Moving on.
2000 Durango SLT with 180k miles and a worn-out 5.9. I know the motor looks clean but it was eating about a quart a week. Body is superb.
Mock up block
LS3
Yeah, that's bad.
LSA rotating assembly
LSA crankshaft
And supercharger to make it a ZL1
Dodge 242 with Novak adapter
Pulleys
Trans and transfer case installed for measurements
Engine is in
Trans painted and ready
Transfer case painted. 6 gear planetary was swapped in with 32-spline input shaft
Trans is in
That is as far as it is so far. I have ordered wiring, driveshafts, and gauges. And I have a bunch of little things to do.
