Thread: 6.0 lq4 / 4l60E in 98 tahoe 2dr 2wd
    I hope this is in the right area and hope that it is ok since the motor is not an LS.
    I have a 6.0 lq4 fromt a 01 yukon. The trans is a 4l60e from a 00-01 1500 truck 2wd.
    I am thinking of swapping out the trans with a 4l80E but was curious if i do this if there are things that i need to take into consideration before i order any parts?
    Mounts and so on.
    I work at a salvage yard so i have access to alot of the parts if need be.
    I am swapping out the Drive by wire to Drive by cable and swapping the ecm for a 00 ecm from a drive by cable truck.
    This is as far as the decisions that i have made at this point.
    Ok so i think i will be saying with the dbw. but Can anyone point me in the right direction for motor mount to put my lq4 in a 98 2wd tahoe. I would like to keep using the stock rubber frame mounts?
    Thanks
    Jan 2014
    Las Cruces NM
    These look real nice. Wish I had used them
    http://www.ls1truck.com/forums/lsx-t...-brackets.html
    Or the dirty dingo mounts
    http://dirtydingo.com/store/product_...oducts_id=1314
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
