Results 1 to 5 of 5
Thread: 1990 obs with lq9 swap, 5spd transmission
    Jul 2014
    What header set up are you all using, I ordered the schoenfeld set up that everyone uses but I'm having an issue with the passenger header hitting the slave cylinder. Any help would be greatly appreciated
    Jan 2012
    warwick ny
    I have a 5 speed in my 1992 but I forgot I have the internal slave setup. How bad is it hitting. On my friends Camaro we had to put a couple on dents in his headers so they would fit around things.
    Jul 2014
    yeah there's no way the passenger side will go in, I'll have to go with some mid-lengths and hopefully those will work.
    Jan 2014
    How does that thing shift 5500+? Mine didn't even like 3500+ rpm.
    Jan 2012
    warwick ny
    I don't know I shift at 6500 rpms.1st to second is fine you can powershift but 2nd to 3rd you need to go a little slower. It doesn't compare to other vehicles that had 6 speeds but it is still fun. I will probably up grade to a tremec 5 speed in the future.
