94 to 02 Wiring intergration
Hi Guys
I'm swapping a 02 LQ4 into a 94 RCSB with a 4.3 and 4l60. I plan on using the LQ4 and 4L80 trans. I'm going through the harnesses and removing the unneeded per Brendan's site (very nice by the way). I would like to use as much of the 02 underhood junction block as I can. . I had the complete truck and removed all the wiring and modules that I figured I needed. Trying to read the prints are confusing and they don't seem to show the connectors I'm looking for. What I can't find is the pin outs for the rest of the connectors under the junction block. Does anyone have this? or can point me in the right direction?
Thanks
I put a 5.3 into my 94 obs V6 truck recently. I followed what he said on the following link and it worked for me. Here is the link: http://lt1swap.com/underhoodfuseblock.htm
- You may not post replies
- You may not edit your posts
