Results 1 to 8 of 8
Thread: 5.3 in 91 Camaro RS
Threaded View
    Oct 2011
    San Antonio TX
    5.3 in 91 Camaro RS
    I know its not a truck but its getting a truck motor and I dont hang to much on ls1tech, thirdgen or fbody sites so ill do it here. Car is currently a roller no motor and driver side seat missing and cluster is in bad shape.
    Ill get pics in a week or so of the car so hang tight.
    5.3 specs
    TSP 224/228
    ARP headbolts
    ARP rod bolts
    LS9 Headgaskets
    Comps trunnion upgrade
    Stock cleaned up 862 heads
    GT45 turbo and homemade hotpipes
    Possible BMR subframe and whole suspension
    Procar seats since driver one was missing
    Autometer gauges since factory one is questionable
    This is gonna be a "budget build" so it will be a slow process. Im still debating on transmission dont know if a 60e or 80e would be better. Its going to be a street strip car with many miles being used as a daily driver. Boost will go up as money allows so the tranny needs to be done right once. Alll of the work will be done by me and my little brothers to keep costs down. Ill try to keep this thread updated but it will be a slow process.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
