89 cruise cable
so the 89 has cruise and the guy wants it to work. what can i do to get the cable to reach the throttle body?
89 c1500 with the 5.3 swap.
I went to the junk yard today and found a complete cable from a 2002 surburban so I took it and it worked. I just put it on an hour ago. So hopefully the cruse will work when the swap is done
Good find Venom,I was wondering about that for my 1990 5.3 swap. I'll put that on my junk yard list, thanks for the tip!
Just buy the cable. The cruise module won't work. And there are two different size knobs on the throttle body for the cruse hook up. So make sure the knob and the cruise cable connector fit with each other on the thottle body.
Just the cable,ok thanks, I'll check for the right connectors also.
The cable from the 96-98 vortecs fit as well.
- You may not post replies
- You may not edit your posts
