Results 1 to 10 of 58
Thread: 1999 2 Door Tahoe LSX Swap
    Austin, TX
    Time to do another swap, this time a 2 door Tahoe. I picked up a 5.3/4l60e combo last night for $350.00. I'm hoping I still have some extra parts laying around for brackets/intake etc.
    Here is the truck I'm working on. It actually will not be here until later today.
    25A59A3E-717B-4BDA-BBE9-33DAB51C677D_1 by MarcusRyan, on Flickr
    Parts List for Reference
    GM 19260102 Engine Flywheel
    GM 12563532 Spacer to resuse stock trans 1
    GM 19257940 Flywheel bolts x 6
    72C2265 Pace Setter Performance Armor Coat Long Tube Exhaust Header
    82-1176 Pace Setter Off Road Y-Pipe
    DD-2575-4 Dirty Dingo Mounts for 88-98 4wd
    Lextech ECM/Alternator Bracket/AC Bracket
    P/N 182-2277 Temp sender adapter 12MM to 3/8 NPT female $9.99
    P/N 182-2268 Oil Sender adapter 16mm to 1/8 NPT female $10.99
    Red 94 GMC Sonoma
    Red 94 Jeep Wrangler
    Red 02 RCSB Silverado
    Red 03 Ford Cobra
    Red 04 CC Silverado
    Red 05 Yamaha Raptor
    I really like red
    Jan 2012
    SW Oklahoma
    Nice truck....that is a steal for a 5.3/4l60e combo.
    Austin, TX
    Here are a few pics of my motor, waiting on someone to buy my other two door before I start ordering mounts, etc.
    Untitled by MarcusRyan, on Flickr
    Red 94 GMC Sonoma
    Red 03 Ford Cobra
    Red 04 CC Silverado
    I really like red
    Austin, TX
    Red 94 GMC Sonoma
    Red 03 Ford Cobra
    Red 04 CC Silverado
    I really like red
    Ottawa, ON
    Wow you got a steal for that engine and tranny! Almost better than my free LS6 with a dropped valve lol. Good luck with the swap, that's a nice looking Tahoe!
    Austin, TX
    Quote Originally Posted by 00shortbox View Post
    I'd take an ls6 over this any day. I do plan on selling the trans though and recouping some if not all of my cost. The overall goal is to do this swap as cheap as possible. That means repinning the factory 99 harness over to ls1 instead of using an aftermarket harness. I won't be stingy on the important things like the mounts, I have a set of ebay's and they are worthless so it will be dirty dingo mounts for sure.
    Red 94 GMC Sonoma
    Red 03 Ford Cobra
    Red 04 CC Silverado
    I really like red
    Jan 2012
    SW Oklahoma
    Quote Originally Posted by redaddiction View Post
    Please document the wire harness as you do it,I have read you can use the obs harness with a 0411pcm and extending the injector wires.
    Austin, TX
    Quote Originally Posted by daytripper67mi View Post
    I've read it also but haven't found any decent pictures or documentation of it. From what I hear though all you do is repin the harness to an ls1 pattern and reprogram the computer. If anyone has any links or info I'd be glad to hear about it.
    Red 94 GMC Sonoma
    Red 03 Ford Cobra
    Red 04 CC Silverado
    I really like red
    Austin, TX
    Ok for my own info this is what I've read for converting a Gen III Vortech to a Gen IV LS1.
    Repin harness to ls1 pinouts
    Change the Injector Plugs to LS1 style
    Reflash PCM
    This spot if for one thing I know I'm missing.
    Red 94 GMC Sonoma
    Red 03 Ford Cobra
    Red 04 CC Silverado
    I really like red
    Lextech is a member here as well.
