Do some years flow better than others?
02 Silverado
02 TrailBlazer
As far as I can tell the only differences are the early heads have perimeter bolt valve covers and the later have center bolt valve covers. The LS6 heads are the only ones that flow different and the have a higher compression ratio.
Thanks. Do you know if the coil packs from the 5.3s will fit on the earlier perimeter valve covers?
02 Silverado
02 TrailBlazer
i'm with jeff on that answer,
no idea on the coil packs , for sure, but i looked very closely at some pics, and they look like they will
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
I'm pretty sure the coil backs will interchange I know the truck coils mount a little bit higher than the corvette f-body coils.
The '01-'02 heads with the 241 castings are supposed to be slighly better from what I've read.
