Results 1 to 7 of 7
Thread: 73-87 Radiator ?
    Mar 2010
    Utica Ky
    73-87 Radiator ?
    Did you change radiators when you swaped in your LS/Vortec or did you just rig the hose's to work? What radiator did you go to or how did you make your stock radiator work. I'm just getting started and I'm trying to get everything togeather. Also are you all running Elec fans or what. Any help is greatly appreciated.
    Wichita Falls, TX
    I've been told by several people they didnt change radiators, I'm planning on staying with my new bigblock '85 radiator
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
    Jul 2009
    Brownfield tx
    radiator
    i don't know how much diff your truck is from a 68 but im running a 2005 vett radiator from pro radiators on ebay 146 bucks works for 6.0 or 7.0 engines plus it is light (13lbs) , has built in oil and trans cooler and is about 3 in narrower than my stocker, height is perfect. only thing is you have to run a water bottle caus it does not have a built in cap but you can get one off of pretty much any newer car. your stock tranny and oil lines hook right up
    Hurley, Mississippi
    I used the stocker but an 03 hose
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    Aug 2006
    Quote Originally Posted by HarleyDave View Post
    Same here.
    86 C10 6.0/4l80e
    I used the stock 6.0l hose with the diesel radiator.
    84 K3500 Suburban, 05' 6.0L, forged, balanced, studded, boosted, 4L80E, NP205, D60/FF-14B, 37x12.50's.
    98 K2500 Suburban, currently undergoing 6.0L conversion
    Mar 2010
    Utica Ky
    Thanks!!
