Results 1 to 2 of 2
Thread: 5.3 heads on a 6.0
    5.3 heads on a 6.0
    i just bought a 6.0 lq4. i found a set of 5.3 heads from a 2000 silverado on craigslist. the owner says there is roughly 47k on them and he is only asking 100.00 for the pair. i know they have a smaller combustion chamber, but how much better will they be if i also swapped an fbody intake onto the motor as well?
    basically anyone know the compression ratio with a lq4 6.0 w/ 5.3 heads?
    Gramercy
    save your money an buy a set of 243/799 heads they flow WAY better than the older 5.3 heads.
    if you mill the heads .025 you'll have a 10:5:1 compression on a stock head gasket roughly. but if not you'll have a 10:2:1 or 10:3:1
    trust me go with a better head.
    2008 GMC CCSB 6.2/6L80e swap
