Ok guys i know i really need to post some pictures but im digital camera poor...
But heres the low down, ive got the 5.3 in the truck all mounted up to the transmission i went to bolt on a lsx type starter and it bolted on but the gear in the starter wont reach the flywheel? The tranny is a 4l60 but doesnt have the shell of a modern day one. The bottom half on the bell housing unbolts just trying to give you an idea of what it looks like/type it is. What are you guys doing about this problem or what type of starter are you using for this swap?
Also i have droped the fuel tank and i have installed my new ac delco fuel pump the one recommended by redheartbeat in his sticky. I want to do a returnless style fuel line set up. When i pulled the tank i noticed that there are four tubes on the top of the fuel pump?? do i just plug up three of them and just use one? which ones do i plug up?
I know it hard to understand what im saying i will try to get a camera as soon as possible.
Thanks for all you help guys!
Brandon
