Thread: 5.3 into a 86 K5 Blazer (Advice)
    Aug 2005
    Spring, Texas
    Hey Guys,
    I did a little research but was wanting to know if you guys could lead me in the right direction for what i will need to make this swap work.
    I currently have a 305 with a 700R4 and it is 4x4.
    I have the complete 5.3, but i need to know about oilpan clearance, motor mounts for 4x4 and what kinda flywheel? What headers will fit?
    If any one has done this swap and has a parts list that would be freakin' awesome!!!!
    Thanks for your help!
    Brent
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Aug 2005
    Spring, Texas
    Come on Guys, surely someone has done a similar swap??????????????????????????????
    I take it you are using the old tranny? If so you will have to get a flywheel conversion from advance adapters i think the part number you need is 712500A and the only other thing with the tranny is that you would have to rig something up for your kick down. I also got the motor mounts from advace adapters but i have heard that there are better mounts out there so you can use the stock drive shafts. The headers that I am running are the ones from street and performance and they are the midlength ones they sell. You may have to modify the front crossmember a little so the pan doesnt rub. If there are any other questions that you have feel free to ask.
