Not that much for trucks. You will have to buy or fabricate new motor mounts. Speed and performance sells adapter plates that allow you to use your stock mounting brackets (www.hotrodlane.cc) They also have the other resources like wiring harness, etc.
Performance will be no comparison between the two. Farmtruc is running 13s with a fairly stock LS1. There is no reason not to do the swap. Others here have done it and are willing to help.
Good luck!
1991 Formula Firebird
2001 LS1/4L60E, 3.23 posi rear
Comp XE 216/216 .577/.577 114LSA cam
918 Springs, hardened pushrods
Yank SS3600 torque converter
PCM reprogrammed for cam and converter
3" exhaust
BRM Adjustable torque arm, tubular read LCAs
Spohn Adjustable panhard bar, front steering brace
Spohn Subframe Connectors
4th Gen style wheels
Bilsteins sport struts and shocks
