Results 1 to 7 of 7
Thread: LS1 conversion on 95 GMC w/5.7
    May 2003
    Sup fella's. Plottin on an LS1 conversion and Im wondering what all will have to be done. I know I can get the engine , harness , and module from GM Performance for around $5,800. Thats about all I know so far on an LS1 swap. Thanks
    East Coast
    custom mounts, modify the wiring harness, we have a write up on how to at http://www.ls1truck.com/howto/99-94wiring.html That is the wiring write up for sticking an LS1 into a 94 fullsize. I know i'm missing a whole lot and someone else can fill it in and when i get the full list, i'll make it into a page and stick it on the site.
    A little something is... you'll need to use a truck intake manifold to run truck accessories, or ls1/6 intake manifold you need f-body or vette accessories. You can't keep your A/C unless you cut the fromt crossmember/frame area, or wait till Allen (fartruc) start fabricating them and you can buy one from him.
    91 s10 - bagged and bodydropped...getting rebuilt
    91 nissan - backhalfed and bagged
    domes pretty much summed it up, you'll run into little gotchas here and there but that's what it's all about, plan as much as you can, that will save you tons of time, and mentally go thru each step and write down every part you can imagine you'll need.
    i'm sure your swap will be very close to mine, once you get it in, you'll never go back, the power is amazing and the mph is much better,
    giving you a complete list is a little more difficult then answering specific questions, i need to get off my ass and do a complete write up from all the notes and pics i have,
    doh,
    see ya online,
    allen
    May 2003
    Albuquerque, New Mexico
    I plan on undertaking such a project before too long. I plan on taking the truck off the streets over the winter, and doing a 6.0L motor in it, at the same time I do suspension, caddy clip etc. to it. It's not gonna be fun, but the end result will be well worth it!
    Also-are all 6.0L blocks iron? Or, do some of them come in aluminum. Which one would I need? I can't seem to find someone who sells just a bareblock. They all want the whole long block, and that's $$$$ for things I don't need.
    BTW-The motor would be going in a '97 Z-71. Thanks guys..
    1997 Chevrolet Z-71 ECSB
    Summit White with Neutral Cloth Interior
    3" Performance Accessories Body Lift
    33x12.50 BFG All-Terrains on 15x10" AR 589's
    Dual Exhaust with 40-Series 2-Chamber Flowmasters
    5% Tint all Around, 5% Eyebrow
    Alpine DVD/CD Player, Alpine Type R Midrange Components, JL Audio Rear Plate Speakers, JLAudio 12w7's (s) Custom Downfire Enclosure, JLAudio 4-Channel to the mids/highs, Precision Power Amp for the Subs
    I belieive the new 6.0 in the SS and escalade are aluminum. I even know where you can get one right now.
    2002 ecsb
    LS1
    JPR stage I heads
    218/224 529/536
    AS&M Headers
    Volant, Magnaflow Dual/Dual
    SSF 3500 4.10
    May 2003
    Just the block, or what? And, where is it at, and how much? Mileage, and can I get some pics of the block if I wanted?
    the aluminum blocks started in 03 for the 5.3L and a tad earlier for the 6.0L,
    this guy is very good and usually has all the parts you need, i know he's a little low on heads, but i know for a fact he has blocks, i just called him two days ago.
    go to smcperformance.com and his name is shaun. great guy, i bought my setup from him and an additional tranny for the tahoe
    keep us updated,
    allen
