Results 1 to 2 of 2
Thread: 6.0 into 87 scotsdale(4x4)
    L76 ints and throttle body
    ok so im gunna put this on my LQ9 can any 1 tell me if the stock body is drive by wire or cable? and if it is wire can i switch it to a cable throttle body?
    THX
    Will
    Hurley, Mississippi
    I did an 86 swap can't help with the 4x4 Q's but the fuel stuff should be very easy on an 87. you will have to change out the E pump to get your pressure up. check the posts it's in here. I ran an ext. pump but plan to change to an 87 tank set up with new pumps to get rid of the hummmmmmmm
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
