It is a straight forward bolt in. I just swaped in a LS1 in place of my 4.8l. Just swap the pan, accesories, water pump, intake, coil packs, and exhaust manafolds. You will need to also swap the flywheel, pilot bearing, clutch, and pressure plate being that you are standard. So far it is running fine on the 4.8L tune but I will get it retuned. Mine is a 2002 4.8 to a 2002 LS1. You will also need to swap the windage tray and pickup tube over inside the oil pan.
