ok so i am looking to put a 6.0 in my 94 z71 (running a cognito lift and 38s with 4.88s) and am wondering which way to go on trannys. I have the 10 bolt right now, this will be swapped for a built 14 bolt hopefully at the same time if not before. I know the 80e will take some more work to get it into my 1/2 ton, and the gears are not as optimal as the 1st is definitely not as deep as on the 60e, and also parts are more expensive. I know 60e's can be built to take a decent amount of HP, and i never hot run my truck around or run it hard, nor do i plan on running it hard even after the motor swap. I'm shooting for like 500/550-ish at the crank for rough numbers, and I do tow a 21' wakeboard boat sometimes, so what is my best option here? Just suck it up and go with the 80e from the get go, or with proper driving habits will the 60e hold up just fine?
thanks
94 K1500
12" Cognito
38" Toyos
20" Hulks
4.88s
GEN III Coming Soon
