i have a 4.8 automatic in my truck and was woundering if it would be worth swaping a 5 speed in it
LOWRADO
05 rcsb 4.8L cai, efi live tune, longtube headers, corsa exhaust, Comp cam tr220 t56 transmission
if your gonna go throuh the trouble ya may as well do a 6 speed,its alot tougher and probably easier to find,not to mention 2 overdrives.
Put a 6 speed in it.
You can buy a shifter conversion kit from keislerauto.com, which will allow you to use the factory shifter hole in the floorboard.
They are a blast in a truck
'92 Fullsize, swb rc
5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
He doesn't have the hole in the floor because he is running an auto right now. I would agree that you should go for the 6 speed because you are going to be happier in the long run with it. Although then you are going to need a different rear gear.....
