Page 16 of 16 FirstFirst ... 6 14 15 16
Results 151 to 153 of 153
Thread: LS6 Intake Swap
  1. #151
    Oct 2010
    Lubbock TX
    Does the stock size belt work with this after you relocate the idler pulley?
  2. #152
    Jan 2007
    Lewisville,TX
    02' 4.8/5.3 with ls1 intake and stock water pump using truck TB. I dented the water neck, cut off the cruise control cable nipple off the TB, will trim the cable guide a little too. Only mocked up now but looks as if it will work. Saves having to change the water pump.
  3. #153
    Wear a diaper on the first road test in the event the throttle sticks open.
