Results 11 to 20 of 22
Thread: 70mm master power
  1. #11
    Yea that c10 is sick. Since you will be building your own setup you should get "maximum boost" by corky bell. You can get it on Amazon. It explains about exhaust velocity and a bunch of other valuable information. Your best bet is finding a set of stock manifolds that will work for your setup and build from there. I'd say go with 2" from the manifolds and step it up to 2.25" on the way to the turbo. Like Allen said a 40mm gate should work just fine as long as it's plumbed into the right spot. For the cold side I would run 3" for the whole thing and rps sells a 50mm box for $100. Also try to fit the biggest intercooler you can, preferably a 4" core
  2. #12
    May 2013
    Awesome thanks I'll def pick up that book. I have a set of truck manifolds that im going to try to see if they fit. Thanks for all the info. Whats the 50mm box your talking about? You have a link to it?
  3. #13
    May 2013
    Scratch that, I'm guessing you meant bov not box lol!
  4. #14
    Haha yea phone corrected it. Meant bov. Here's a link http://www.racepartsolutions.com/ind...nuf?Itemid=564
    They also have a bunch of other turbo stuff like oil feed/return, wrap, boost controllers, fuel stuff, vacuum line, etc
  5. #15
    May 2013
    Haha yea it happens, thanks I'll check them out.
  6. #16
    May 2013
    How bout a fuel system for this set up? I have a 16gal fuel cell I'm mounting under the rear of the bed. What fuel pump, size lines, injectors etc...
  7. #17
    Depends how many horsepowers you want
  8. #18
    May 2013
    Well I only wanna buy once, I have a 5.3 I plan on building up eventually with a bigger turbo. With that set up I'd like to be around 700rwhp, this set up I'd be happy in the 500rwhp range.
  9. #19
    get one of the inline Magnfuel or Aeromotive pumps that support your hp requirements and 100lb injectors.
  10. #20
    May 2013
    I was looking into the areomotive a1000 pump. What brand injectors do you recomend?
