Page 22 of 32 FirstFirst ... 12 20 21 22 23 24 ... LastLast
Results 211 to 220 of 316
Thread: my official build thread
  1. #211
    sorry bout the truck bud, hope the fix isnt nothing major! checked out the vids, seems like it spools quick? definitely like it
    Simple: 408 on steroids!
    single digits coming soon!
  2. #212
    Oct 2011
    San Antonio TX
    As long as it isnt kinked at the bend it should be able to be straightened out. If not go get you a back half off another truck and weld it on there. You will see a weld and overlap on the frame closer to the cab, thats the rear half of the frame that can be replaced. Done a couple myself and insurance companies loves gm for that.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  3. #213
    cool thanks man. I also threw around the idea of fourlink and backhalfing it but idk if I want to that far just yet know that guys are running 9's with just shock relocation. Skeet, yea it does spool very quick, especially at interstate speeds.
  4. #214
    Ponca City
    How do you plan to mount the seats to the truck?
    Slowest in Oklahoma...
  5. #215
    Pittsburgh, PA
    with the bent frame and get a backhalf kit with some ladder bars and fat meats
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  6. #216
    George you thinking ladder bars over 4 link? I know losing the leaf setup would lighten it up a good bit. Shawn, I plan on making some brackets for the seats. I'll take pictures as I go through it. Gotta get cage figured out first
  7. #217
    Pittsburgh, PA
    Quote Originally Posted by o2camaross View Post
    Allen once said to two of us this past yr
    " a 4 link has a thousand settings and only 2 work"
    ladder bar typically is setup once then shocks get slight adjustments
    4link= street/strip
    ladder bar= track winner
    412 Motorsports
  8. #218
    Pittsburgh, PA
    also fastest LSX truck is ladder bar, 2nd fastest I believe is a ladder bar and 3rd {nelson's truck} ladder bar
    hayhauler / La Whippet / farmtruck
    412 Motorsports
  9. #219
    Good deal! Ladder bar is simpler too. You think I would need a rear sway bar?
  10. #220
    Pittsburgh, PA
    9" with a anti roll bar or drag bar is what id use and that is what allen has
    his chassis is a work of art
    412 Motorsports
