LQ4 with front mount turbo what cam?
Ok to start off i blew a 4L60-E last week and in the process of looking for a trans i came across a great deal on an LQ4. While the trans is out im going to swap the LQ4 but before i drop it in the truck i want a better flowing cam. So this is where i need help what is my best option? also i will need a good set of push rods, valve springs, non-adjustable roller rockers, Gaskets, and should i go head and swap out lifters while im in there?
2007 silverado Reg Cab Short bed, circle D 3200 stall, 4L80-E, Trick Performance Turbo 76mm AR96, 44lbs injectors, TSP 220/220 581/581 114lsa cam,PRC double valve springs, Nelson Performance tune, mcgaughy 5/7 drop
2000 Camaro Z-28, Vigilante 3600 stall, 4l65-E trans, LS6 heads, pacestter LT, SLP Airlid, comp 224/230 581/589 114lsa ***SOLD***
2007 Trailblazer SS, Stock
