If I understand correctly.. you can only make one fan cuton (high/low) temp adjustable? If that is the case I would have to say high. If you are installing fans on a truck where we originally didnt have fans, it all depends on what size/cfm fans you go with to how low you can set the temps. And like Allen said, it depends on what thermo is in there too. For a generic number I would have to say 170 for the low speed and make the high adj between 170-200 and include the a/c high speed cuton.
2000 Silverado, RCSB, 2wd w/ a few mods.
Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
2001 Tahoe LT 4wd
Stock, daily driver and tow vehicle.
