Results 1 to 5 of 5
Thread: LT1 and LS1
    East Coast
    Does anyone know of pictures of the LT1 PCM pin out and the LS1 PCM pin out?
    Thanks
    91 s10 - bagged and bodydropped...getting rebuilt
    91 nissan - backhalfed and bagged
    I have the pin out for the ls1 and truck, don't have the lt1, i think gmcwantsls1 has a disk with stuff on it, maybe he'll chime in.
    i can fax them to you.
    later chief,
    allen
    East Coast
    Thanks man.. You have the number. I can't wait till tomorrow to get it... :thumbs:
    Florida
    These were posted over on Fullsize Chevy a few weeks ago...i thought i might need em, guess not...good thing i kept them
    Brandon
    LT-1 computer wiring harness. Pin to plug
    ok these are all done by harness color and pin #
    Blue Connector
    1 Tan w/white= ECM ground !!! very important
    2 Lt Blue w/white = tranny connector
    3 pink = need to double check
    6 Dk Brown = tranny conn
    9 Brown w/white = Check engine light = EGR need to double check
    10 Dk Green w/white = Canister purge
    11 Tan w/Brown = tranny connector
    20 White w/black = Underdash connector # 6
    22 Dk Blue = knock sensor
    28 Yellow w/white = tranny connector
    30 Tan= Underdash connector #9
    Black Connecter
    2 Red w/black = Dist diag (grey)
    3 Pink w/black = Dist diag (grey)
    5 White = Ign Module
    6 Black = Tranny connector = TDS = ECT
    7 Lt green = tranny connector
    8 Green w/white= VSS output
    12 Yellow w/black = Tranny connector
    13 White = Tranny connector
    14 Red = Dist diag (grey)
    15 Orange = Underdash connector # 16
    16 Black = MAP = IAT
    19 Yellow = MAF
    20 Lt Blue w/black = Dist diag
    28 Grey = TPS
    29 Grey = MAP
    30 Pink = MAF
    31Orange Underdash connector #16
    Red Connector
    2 ECM Ground IMPORTANT!
    3 Black = inj # 1
    4 Lt Blue w/black = inj #4
    5 Yellow w/black = Inj #6
    6 Red w/black = inj #7
    7 Green w/white = Fuel pump turn on
    9 Grey = EGR
    10 Blue = coolant fan relay turn on #2
    11 Dk Green = coolant fan relay turn on #1
    14 Brown = Air pump turn on relay
    18 Tan/white = ECM GROUND IMPORTANT
    19 Lt Green w/black = Inj #2
    20 Black w/white = Inj #5
    21 Pink w/black = Inj #3
    22 Blue w/white = Inj #8
    25 Lt Green = to vats
    31 Purple = VSS
    32 Yellow = VSS
    Clear Connector
    1 Lt Blue w/white = IAC
    2 Lt Blue w/white = IAC
    5 Lt Green w/black = IAC
    6 Lt Green w/white = IAC
    7 Tan = pass side O2
    8 Purple = Pass side O2
    14 Lt Blue w/black = brake switch
    15 Orange w/black = gear shift indicator
    16 Red w/black = Tranny connector
    19 Tan w/white = Drivers side O2
    20 Purple w/white - drivers side O2
    21 Tan = IAT
    22 Blue = TPS
    23 Lt Green = MAP
    25 Yellow = ECT
    28 Pink w/black = Tranny connector
    29 Blue = Tranny connector
    30 Red = Tranny connector
    32 Black = Tranny connector
    All these were done with an ohm meter and the Painless harness. If you have a stock harness and dont know whats what this may help you.
    485rwhp/440rwtq SAE
    East Coast
    Thank you Brandon. This is 1 step closer to the ls1 and lt1 pcm conversions for the s-10's.. I just hope this shit works!
