you may have to replace the cluster, check all the fuses, take the possitive and negative battery cables off the battery, touch the positive cable to the negative cable. NOT THE BATTERY!!! hold the cables together for 1min, this will clear out any logic lock in the modules, its like rebooting your home computer. reconnect the battery, start the engine. if it still doesnt work, get a tech 2 scanner, preform a gague test to see if the needle moves, if it moves than check the pcm output to the cluster. if not, reprogram the cluster,if that doesnt work than its time to replace it.
