I have no reverse lights. Where should I start? Im assuming the switch on the manual shift shaft controls the lights so i tested that with another one and that did not help. Any ideas? thx
02 Silverado
02 TrailBlazer
is there a sensor on the actual transmission that controls that? maybe check the fuse panel?
I changed the fuse also. The only thing on the tranny I saw was the neutral safety switch. I plugged another one in but that didnt help. Thanks.
02 Silverado
02 TrailBlazer
Also the motor and tranny have been out of this truck numerous times by the previous owner so it could be a pinched wire. Where could I get a wiring diagram of some sort that would help me locate were the wire from the switch etc go. thx
02 Silverado
02 TrailBlazer
