I finally got my fans hooked up to the pcm!!!
After a long time of dealing with the toggle switch and keeping an eye on the temp gauge in traffic, the pcm does it for me. Man, what a relief. It's so nice to have it automated, ok enuff of that, on to the tech stuff.
I got most of my parts from partsexpress.com. They have almost everything you need for electronics and stuff. The relays were less than 2$ each. The wiring i got from NAPA, and the connectors same place.
For those of you wanting to do this to the truck pcm, it also supports it, it's the same as the z28. I'll find the pin if anyone cares to know.
I used some circuit breakers instead of fuses, i may fuse it later, but it's safe for now.
I set the pcm to turn the fans on at 185, and turn them off at 179. On the highway I run about 176-178 and at idle , in the hot summer time, i run about 181 with the fans on. So, the fans will never shut off in traffic, but as soon as i get going and moving my temp will obviously drop and they will go off. I'll tweak it later, but i think that's the perfect setting for my app.
later,
allen
