Thread: 2002 gauge Cluster Bulbs
    Aug 2005
    Spring, Texas
    I was wanting to get a regular white face gauge and put in some orange bulbs, has anyone done this on a newer style truck? I don't think our bulbs pop out, but i can solder them in.
    Thanks, Brent
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Aug 2005
    Spring, Texas
    someone has to have changed the bulbs out.... Come on guys.
    Apr 2003
    I just did this, but in blue.
    I got 3 6 bulb LEDs and 3 5 bulb LED's. I was able to take the stock bulbs out of their holders and reuse the holders for the LEDs. I set em up 2 ways, one with the 6 bulbs in the main part of the cluster (tach & speedo) with the 5's at the other gauges (voltage, gas, oil, temp) (Setup 1) and then I switched em (Setup 2). All 6 bulbs ran ~27 total from superbrightleds.com (they have amber too).
    Here's the original gauge.
    Here's the setup with the 6 bulbs in the speedo/tach part
    Here's the setup with the 5 bulbs in the speedo/tach part
    I think the 5 in the speedo/tach looks the best and the most even. I think if I were to do it again I would use 6 5bulb leds to spread it all out, and I woudl also get the new bases (Twist Lock) so i wouldn't have to mess with the old ones. Much easier to do.
    Andrew
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    Aug 2005
    Spring, Texas
    awesome, looks good i am going to the led site right now.
    later, Brent....
