I am in the process of swaping a 5.3 2001 truck engine into a early 68 p.u. And have a couple electrical questions.
1. I need to install a OBD 2 Data Port. But I need help figuring out were the
wires go to. I think its got 5 wires.
2. I have a wire coming off the engine harness. That is Brown and says it
goes to the malfunction lamp control output. Thats cool,but whats the
malfunction lamp control output. Or were is it located ?
3. I am planning on running a Summit in line hi-press. fuel pump,in line fuel
filter and a relay for the pump. Does the relayor fuel pump have to be
hooked into the computer.
If any of you can help, maybe give me some info. I will be grateful. THANKS !
HAPPY SAFE HOLIDAYs
