Results 1 to 5 of 5
Thread: Low pressure switch
    hey guys, anybody know where to get a low pressure switch.
    I'm wanting to turn on a device at a certain pressure.
    No need for anything over 20psi, adjustable would be nice.
    I've seen and have one of those triangle Hobbs, black and brass pressure switches, but I'm looking for other options.
    thanks,
    allen
    Oct 2003
    TeXas
    you get the beast running yet????????
    http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
    RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
    04 GTO
    Both Tuned By: ME
    Getting closer.
    Dec 2005
    Chicago-ish
    I just ran across this post. If you&#39;re still looking, pneumatic HVAC controls sometimes use P-E switches (pneumatic-electric). I found two in a local supply house catalog. The first one measures about 1 1/4" x 1 1/4" x 2 1/2", has an adjustable set point of 2-25 psi, 2 psi fixed differential, and 20 amp SPDT contacts. It isn&#39;t listed in the specs, but I do believe it has 1/8" FPT. It retails for &#036;72.
    The other one measures about 1 1/4" x 3" x 4". It has a SPDT switch, rated at 13.8 amps (both controls are rated at 120V). It is adjustable from 1 to 20 psi, has an adjustable differential of 1-5 psi, and has 1/8" FPT. It is rated for 50 psi. It retails for &#036;84.
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
    Originally posted by MikeGyver@Jan 9 2006, 04:56 PM
    I just ran across this post. If you&#39;re still looking, pneumatic HVAC controls ...
    Thanks a lot for the info Mike&#33;&#33;
    Also, I really appreciate you sending the video&#33; I&#39;m sure it&#39;s going to help out.
    thanks,
    allen
