Results 1 to 2 of 2
Thread: mirror question
    Apr 2005
    will a 2000 rearview mirror with temp and compass work in my 99 i just have a compass on my mirror and want the temp too... just wondering if it will just plug in..is the temp reader in the mirror itself or will i hafto run a wire???
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Jun 2005
    You will need to run the wires for the temp sensor. Also you will proably need the plug from the one witht the temp sensor as yours won&#39;t have the wires in the pins needed for the temp sensor. The temp sensor actually sits somewhere behind the grille.
    Read this thread, it should help you to better understand what you are trying to do. I did this swap in my 98 and thus far have not boughten the temp sensor so as of now my mirror reads "OC" for the temp (open circuit).
    http://www.offroad-tech.com/forum/sh...ad.php?p=27217
    Conrad
    “Learn as if you were going to live forever; Live as if you were going to die tomorrow.”
    “In dating and mating, what is finally settled for is always a function of what is available.”
    http://img.photobucket.com/albums/v7.../Signature.jpg
