does any one have computer pinout for a 03 1500 hd 4x4 6.0 i am looking for what color wire goes to what pin in the computer and what it is for
03 1500HD 4x4 6.0 on 33"
K&N intake, Pacesetter LT, 3" true dule orp, Magnaflow, Comp cam 237 242 .603 .609 112, Patriot Gold springs and Ti retainers, stock ported heads, ASP Underdrive pulley, 42# injectors, 160 tstat., 05 E-Fans, Nelson Fan Harnas, tb bybass, MSD wires, NGK tr55, Ported tb, Transgo HD2, yank 3200 conveter, HP tuners, Walbro 255, 4.56s
Yes, What do you need to know??
the o2 signal wire and the temp signal wire
They are all on the Blue plug.
ECT Signal wire is YEL pin 74
HO2 Low Signal, Bank 2 Sensor 2, TAN Pin 25
HO2 Low Signal, Bank 2 Sensor 1, TAN Pin 26
Ground BLK/WHT Pin 27
HO2 Low Signal, Bank 1 Sensor 2, TAN Pin 28
HO2 Low Signal, Bank 1 Sensor 1, TAN Pin 29
HO2 High Signal, Bank 2 Sensor 2, PPL Pin 65
HO2 High Signal, Bank 2 Sensor 1, PPL Pin 66
Ground BLH/WHT Pin 67
HO2 High Signal, Bank 1 Sensor 2, PPL/WHT Pin 68
HO2 High Signal, Bank 1 Sensor 1, PPL/WHT Pin 69
thanks man thats what i needed
NP dude anytime...
