Thread: flex-a-lite or '05 fans?
    Jul 2005
    Fort Sill, Oklahoma
    I've decided that the next upgrade going into my truck is going to be the efans. I'm tending to favor the flex-a-lite fans over the '05 or camaro fans becuase I wouldnt have to upgrade to a larger radiator. Also I've read that the draw on the electrical system is substantially less with the flex-a-lite fans than the others. Is this all correct? It seems more ppl seem to go with the '05 fans... is there something I'm missing? Any downsides with the flex-a-lite fans? Do the flex-a-lite fans require retuning the PCM(is there a way around it?)? I also think an alternator upgrade wouldn't hurt since I'm always running around with the A/C on and I have a 2000W amp under the back seat. Any thoughts on that or recomendations on that? Delphi's alts caught my eye. What does everyone else run and what can I learn from your setups? thanks...
    ohh yea one more thing... how would a 160 degree thermostat play into all this?
    Black 2003 Chevy Silverado LS, 2WD, Extended Cab, Short Bed, 5.3L V8, stock 4L60 tranny, Crane Cams tune, 77 Series K&N intake, 30 Series Flowmaster exhaust, 285 60/R16 Goodyear GTII tires, aluminum alloy rims, 2 10" Rockford Fosgate Stage 2 subs, 2000W RF amp, SilverStar Halogen headlights.
    Jul 2005
    The problem with the 05 fans is that they are NOT a complete kit. You will need the harness to make it work. Nelson has it for $90. Also it would require a computer reprogram to make it work. However, you are already going or headed that ways anyway since you need to have a reprogram to make the most of what you got.
    The Flex-a-lite fans have a VSC (Variable Speed Control) unit to make it work. i don't like it as much because it would be doing it with a sensor behind the radiator and not taking the actual fluid temps. The plus side is you don't have to retune your ECM. You could also get the fans alone and have the Nelson harness make it computer controlled. Several people have said they had problems with the VSC
    Apr 2005
    05s are sweet ... id get em but my radiators too small and they take a lot of juice... i didnt want to buy a new alt
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Jun 2005
    Cumming, GA
    Originally posted by UCLArmyGUY@Aug 16 2005, 08:39 PM
    I&#39;ve decided that the next upgrade going into my truck is going to be the efans. I&#39;m tending to favor the flex-a-lite fans over the &#39;05 or camaro fans becuase I wouldnt have to upgrade to a larger radiator. Also I&#39;ve read that the draw on the electrical system is substantially less with the flex-a-lite fans than the others. Is this all correct? It seems more ppl seem to go with the &#39;05 fans... is there something I&#39;m missing? Any downsides with the flex-a-lite fans? Do the flex-a-lite fans require retuning the PCM(is there a way around it?)? I also think an alternator upgrade wouldn&#39;t hurt since I&#39;m always running around with the A/C on and I have a 2000W amp under the back seat. Any thoughts on that or recomendations on that? Delphi&#39;s alts caught my eye. What does everyone else run and what can I learn from your setups? thanks...
    Yeah, most everyone who has e-fans has had to upgrade the 105 amp alternator. The only person I knew of who did not upgrade his alt, had to get his idle RPM bumped up to keep the alt turning fast enough. F-body fans do fit the standard 28" radiator. If you look at the flex a lites for the 28" radiator and look at a set of the F-body fans, they look nearly identical. The flex a lites can be seen here:
    http://www.flex-a-lite.com/auto/html...-electric.html
    Now, most people tend to think of going with these:
    http://www.flex-a-lite.com/auto/282-99815.pdf
    but, if you notice, they only fit a 34" radiator, like the factory &#39;05 e-fans. I am currently running my clutch fan, as it is a considerable amount of money to buy a set of e-fans (say &#036;100 for F-body fans, &#036;90 for Nelson harness, and then &#036;150 or so for a new alt). Another advantage to running F-body fans is that if one or both motors should crap out, you can get replacement motors at the auto parts. Anyway, a 160º t-stat can be added at any point (I am also running one of these).
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    Jul 2005
    modesto, ca
    The flex a lite fans are noisier that OE style. My buddy had a 98 Z71 with flex a lite fans, they sounded like a buzz saw. Also he ended up installing a sensor in the head to run the fans, the variable thermostat would not turn on in situations when air flow was low or not at all.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Oct 2004
    Rightchere
    Forgive my stupidity, but could you wire up flex-a-lites to a simple toggle on/off switch? No VSC, no reprogram.
    Seems to easy, I&#39;m missing something?
    Josh Hucks
    ^^^TCI SF3000 for sale^^^
    2002 Chevrolet Silverado 1500
    4.8L/4L60E
    *358.9 HP/ 424.8 TQ Dynojet*
    Exterior Mods: lowered, shaved, 20&#39;s
    Performance Mods: Nitrous, CAI, Predator, Gibson headers and exhaust, NGK&#39;s, TCI shift kit & servo, 4.10&#39;s, Eaton posi
    Interior: stock, center console removed, Alpine 12" sub
