I read the threads about needing to change the alternator from the 105 Amp to something larger when you install the '05 elec fans. I found an alternator that is rated at 130 Amp, is that enough? I had to prove to myself that the larger alternator was needed so I pulled my LT1 fans and placed the '05 fans near the rad. My harness is from Nelson so just A/C the alternator keeps up, just temp (both fans low) the alternator keeps up, but with A/C and temp (both fans high) the volt gauge goes to 11.5 Volt real fast and the A/C will not stay on. Interesting.
So what is the minimum amp alt needed to run the fans and still keep the system running properly?Thanks
