Results 1 to 8 of 8
Thread: 9006 to 6005 headlight bulb adapter?
    Oct 2003
    Does someone make an adapter that will plug into the 9006 plug and make it to where i can put a 9005 bulb in or am i going to have to rewire the plug?
    Im swapping my factory GMC Sierra headlights for some factory GMC Denali headlights. Problem is the sierra take a 9006 low beam and the Denali take a 9005 low beam
    Thanks for any help
    Brad
    http://www.danasoft.com/sig/bsnuggs.jpg
    2001 GMC 1500HD SLT 4X4 CCSB 6.0L
    Mac Performance Intake, 05 E-Fans, Magnaflow Catback, Pacesetter LTs w/ Custom "ORY", Comp Cams 210/210 555/555 112 lsa, Comp Cams 918's, Hardened Pushrods, HP Tuners, BB Thermostat mod, TBBP, EGR Delete.
    Not EVERYONE can be a Louisianaian, it's an art form and a gift from God!!
    Treat every situation like a dog; If you cant eat it or screw it-- Piss on it and walk away
    May 2004
    I haven't seen a plug and play adapter like that yet but I have seen these for upgrading to a higher wattage bulb. racinglab Maybe they can help you out but I think you'll have to rewire a new socket in place.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Apr 2003
    I think Your in Luck,
    I have a set that I got with my APC projectors.
    I'm no longer using the projectors so I beleive I still have the adapters lying around.
    email me at jcreede@nycap.rr.com
    and I'll try to locate them for you.
    99 Step Side Cardomain
    99 Reg Cab Step side
    03 Ext Cab Z71
    03 GMC Car Domain
    Oct 2003
    Email sent Thanks man
    just plug them in. The plug is the exact same. The bulb base is just a lil different. But they should just work if you plug them in.
    San Marcos Texas
    The Denali headlights come with the adapter harness attached to the headlights.
    newburgh, NY
    Quote Originally Posted by budrun View Post
    It's not the base it is just that the 9006 have a painted tip for use in low beams and they are 55 watt vs 9005 unpainted and 65 watt bulb.
    whoaaa back from the dead on this one... phew 4 years ago
